Latest post 12-28-2008 2:40 PM by Spiros. 2 replies.
Page 1 of 1 (3 items)
  • 12-28-2008 7:44 AM
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Laptop infrared port
    Hi all,
    I'm thinking of using an old laptop I hav in order to make a small media center based on the xbmc medial player which I concider it very good.
    Two issues I'm considering.
    1st. Is it possibel to use the infrared port of the laptop (which ideally is infront) as a receiver to command the media center?
    2nd. Has anyone setup the XBMC media player to accept commands from Beo5?
    All input are highly appreciated
    Regards
    Spiros
    Best regards
    Spiros
  • 12-28-2008 8:58 AM In reply to
    • madskp
    • Top 500 Contributor
    • Joined on 11-06-2007
    • Denmark
    • Posts 111
    • Gold Member
    Re: Laptop infrared port
    The Built in IR recievers in laptops are for transfers of files rather than remote control. Those recievers are only for short range and it will probably not be usable for remote controlling the system.
    I don't know about the BEO5 and xmbc
  • 12-28-2008 2:40 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Thought so bu wanted to give it a try!
    Many thanks for the input!
    Best regards
    Spiros
