Hello Odinn
Welcome to BeoWorld, its a great forum for getting lots of useful information and having fun.
This thread goes back a long time now but the good news is that my CDX has continued to run faultlessly. Things get tricky when the plastic parts start to break up and you do need a certain amount of luck that the repair will hold together for a reasonable time.
The first photo that I have shows the assembly removed from the CDX and the white plastic section which had broken. This part is needed to activate one of the limits.
The second photo shows a close up of the broken plastic section and the spring insert that I made to replace the lower follower.
The final photo shows the spring clip in position and this arm was then able to make its limit properly.
Perhaps you could provide a photo of the broken part on your machine as that will help identify the problem that you have. You could then ask around to see if there are some spares available - obviously an easier solution compared with making up parts yourself.
Hope this helps
Regards
Geoff
