Latest post 12-30-2008 4:34 AM by ChrDH. 9 replies.
Page 1 of 1 (10 items)
  • 12-21-2008 4:53 PM
    • ChrDH
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Denmark
    • Posts 493
    Christmas came early this year; just been given a Beomaster 6000 (1980'ies model)
    Hi there, just wantet to share this. My cousin just gave me a working and mint Beomaster 6000 which he found at a garage sale and bought for 5£!!!.
    More to follow tomorrow...
    best regards
    Christian
    Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
  • 12-21-2008 4:58 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Christmas came early this year; just been given a Beomaster 6000 (1980'ies model)
    Very niceWink
    CraigSmile
  • 12-21-2008 7:36 PM In reply to
    Well done!
    I was given a Beosystem 6000 earlier this year, and am still thinking myself lucky. If Robert in Southport is reading this, then thanks again!
    The Beomaster 6000 is a great amp :)
  • 12-22-2008 6:26 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    When i plugged it in yesterday it worked fine, except from the volumen control not responding. So i fetched the sercive manual and opened the beast up. The rubber band from the servo motor to the potentiometer was wery dusty so i cleaned it and it works just fine now, I use it as an headphone amp at the moment, together with a beogram cd 3500.
    It got some problems with the display (which i recon is common), there is no light in the volumen scale, it can only display 75,4 mhz although the radio and clock works fine, but that is not a big problem... But wow it is a large piece of kit! Cant really imagine the BM8000 being even larger!
    best regards
    Christian
  • 12-22-2008 7:29 AM In reply to
    • ridax
    • Not Ranked
    • Posts 44
    The frequency display problem is the prescaler chip if I remember correctly.
  • 12-22-2008 10:07 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    Thanks, is the IC easy to replace? And where can one get the spare part?
    best regards
    Christian
  • 12-23-2008 12:54 PM In reply to
    • ridax
    • Not Ranked
    • Posts 44
    It is a U264B but it can be quite difficult to source as it is discontinued.  Once you get it, it should be no problem to replace if you have basic soldering skill (you can cut the old chip away to ease desoldering of it).
  • 12-24-2008 6:45 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    okay, thanks
    Christian
  • 12-27-2008 4:09 PM In reply to
    Just came back from a holiday.
    A Beomaster 6000 like yours are the same size as the Beocord 6000-8000-9000 basically. The Beogram 6000-8000 is nearly the same.
    When you get to Beomaster 8000 you will be in trouble if you don't have the original type of stand.
    The Beomaster 6000 stand is 105cm and the Beomaster 8000 is 120cm in lenght.
    As you are Danish you can read all about my B&O here:
    http://www.hifi4all.dk/forum/forum_posts.asp?TID=66882&PN=2
    Your problem with frq is covered too. I never had the problem with the 2 6000's of mine but now I know why.
  • 12-30-2008 4:34 AM In reply to
    • ChrDH
    • Denmark
    • Posts 493
    I am back from holiday too now, thanks for the post and link.
    best regards
    Christian
