Latest post 12-22-2008 6:41 AM by Christian. 7 replies.
Page 1 of 1 (8 items)
  • 12-19-2008 3:47 AM
    • Wings
    • Top 200 Contributor
    • Joined on 04-17-2007
    • Hong Kong
    • Posts 341
    What have I got?
    I picked up a motorized stand from next to the rubbish room.  It looks to be for the MX series as it resembles the stand for my MX8000, only smaller.  The front portion of the foot is 23" wide, the stand is about 15.5" deep and about 14" from the floor to the top of the lip on the tray.  The tray itself is secured to the stand by 6 screws and the tray measures 17.75" by 5.5".  It comes with a cable with 4 pins.
    Also, how do I test to see if the motor works?
  • 12-19-2008 5:57 AM In reply to
    Re: What have I got?
    Could it be the motor stand for the older smaller MX's?
    And yes, the older MX TV's motorized stand had a four-pin DIN cable instead of the newer 5-pin.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 12-21-2008 8:41 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Thanks.  I would agree with you but I am not certain which MX models it might fit.
    Also, is it possible to connect the 4-pin to my MX8000 to test whether the motor works?
  • 12-21-2008 1:09 PM In reply to
    Shouldn't hurt anything. May not work, though. Don't exactly know what the 5th pin is for.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 12-21-2008 1:27 PM In reply to
    • Foxtrott
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Vienna, Austria
    • Posts 500
    Hi Wings
    Testing the stand with your MX8000 won't work. First the plug won't fit but even if you manage to connect the stand you won't be able to control it. The MX8000 (and the MX4200) are based on the BV1 chassis and not on the same chassis as the older MXs, so the whole control unit for the stand is different.
    To test your stand you will need an MX from the MX3500/4000 or MX5500/6000/7000 range.
    Foxtrott
    "The first thing we do, let's kill all the lawyers."
    Henry VI, Part 2 William Shakespeare
  • 12-22-2008 5:13 AM In reply to
    • Wings
    • Hong Kong
    • Posts 341
    Thank you, gentlemen.  I guess I will let it sit in my flat until I can borrow the appropriate model to test out the motor.  Just more B&O to add to my collection.  ;)
  • 12-22-2008 5:29 AM In reply to
    Does the MX3000 have the ability to control a motorised stand?
    I recently swapped the back cover for another cover and saw a covered up input that would seem to match a stand input, although I've not had a chance to test it!
    cheers
     GUY
    Train Hard - Run Fast - Hit to Kill!!!
  • 12-22-2008 6:41 AM In reply to
    • Christian
    • Top 100 Contributor
    • Copenhagen, Denmark
    • Posts 626
    No. I am sorry, the chassis comes from Philips, so no motor stand there...
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
