Hello Raoul,
Currently my Beo5 runs on 1.30a which (if i understood correctly) cannot send codes to 3rd party products
Not true, with that firmware beo5 can send codes to 3rd party products.
But that firmware version has some other technical issues and need to be upgrade to 1.34a firmware (at least).
If I understood one post correctly, currently there is a version 1.40
out there which requires a new config tool and doesn't have 3rd party
products support...
True, the "Beo5 3rd party XML generator" program needs little changes.
I was thinking of going to a B&O dealer and having the beo5 updated
to 1.34 but since there is a newer version out, do you think there is
still a chance to upgrade from 1.30a to 1.34?
That's a very good question, but you must ask your dealer I'm afraid...
