Well, got my BL8000s installed yesterday and all my other B&O stuff mounted properly. WHAT A DIFFERENCE!!! All connected to my Onkyo TX-SR875 with 8000's as front L/R channel and BL4's as rear L/R.
My issue is this...At bedtime I turned my Sky HD off then turned off the Onkyo. Pottered about a bit for and went back into living room. 8000's still powered up (green light on) and giving off a low hum. Must have left them for a good 20 mins
Switched the Onkyo back on and must have inadvertently pressed the DVD button on the remote and the speakers almost instantly powered down. Then pressed the 'standby' button on the Onkyo to switch it off again and low and behold the 8000's powered back up!!!
I thought the 8000's powered down when no input is received? I'm at a loss as to explain WHY the speakers would power back UP from a powered DOWN state when I switch the receiver OFF?????
Anyone???
Scott
