1st March February 2012
Latest post 12-22-2008 10:50 PM by Evan. 25 replies.
12-17-2008 9:53 PM
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
I believe they were hardly sold locked and tied to an network provider. You can just go to your dealer. It should work with any GSM provider which most are. Cheers JK
SWISS_2
- Neuchatel, Suisse
- Posts 552
I saw your post, and took a quick look at EBAY USA. There are three available used for an average of $ 399. USD. Good Luck !
lausvi
- Helsinki - Finland
- Posts 498
I have one, bought from eBay. Unopened without warranty, approx. 500 EUR. (The B&O shop price here: 1190 EUR). Has worked perfectly and I use it quite a lot. Switch from Nokia phones to Serene caused that I rarely send text messages anymore as it's quite slow with Serene. Camera is usefull but so low resolution that the pictures are hardly for any use outside the phone. No changeble ringtones but the ones installed are quite nice and at least different from any other phone.
Bang & Olufsen - The art of controlling sound, picture and light
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
I love mine, but since I live in North America, I rarely use it. It is a tri-band phone and I'm not sure where else that affects its performance, but here it means sticking closely to metropolitan areas. That issue aside, I really love the phone. It's elegant, simple, and now that everyone owns an iPhone, still feels very special. It also gets more attention than the iPhone, so be ready for comments.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
I recently went to look at an iphone and the saleslady grabbed my Serene out of my hand and wanted to know all about it.
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Stars
- London
- Posts 1,483
All Serenes are unlocked. The Samsung models might not be however. My Serene is still going strong, although I now use two phones. The Serene for private use and a Samsung smart phone for email and web use.
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
I want an iPhone also, but now that everyone and their mom has one its not a head turner. I like comments and I like being different, that almost sells it on its own. The carrier that will be supporting it if I do choose to get one would be AT&T, and they're 3G network. Mr. TripEnglish, do you think you could expound upon this tri-band business? I'm afraid i haven't familiarized myself with that and am alarmed by this as I too reside in the states, but spend most of my time in suburban areas.
Razlaw
- Illinois
- Posts 1,770
Hope you do not mind my input on the triband issue. I find the phone works 90% of the time for me. I live near the Iowa/Illinois border. There are some rural areas where it will not work. Driving across Illinois to Chicago if I take the northern route I have a full signal the entire way. If I take the southern route the phone is dead for about 1/2 of the trip. Interestingly the southern route has many more cities and larger cities than the northern route. I recently drove to Rochester Minnesota and had a full signal for most of Iowa and part of the drive in Minnesota. I do find that many times in the interior areas of buildings or below ground level portions of buildings it will not work even though it has a full signal outside. My understanding is that there are four different frequencies that cell phones use. The Serene has three of them, but only one is used by AT&T and other US carriers. If you are in an area where the carrier uses the frequency the phone does not have, it will not work.
Affineur
- Joined on 04-27-2008
- United States
- Posts 90
The tri-band issue is significant in the US and you should check the coverage in your area for AT&T and TMobile. The Tri-band Serene phone is compatible 900, 1800, and 1900 MHz systems. In the US a fourth frequency (850 MHz) was added (primarily to the AT&T system) and TMobile has an arrangement with AT&T to swap secondary use of their 1900 MHz signal for secondary use of the AT&T 850 MHz signal. This is the basis for the so-called "quad band " phones which are now the standard in the US (with the exception of Verizon and a couple ofother providers). It has been noted that the 850 MHz frequency provides more reliable coverage in areas with obstructions (tall buildings, mountains, etc.). The issue of coverage for a Serene arises with either provider for the following reason. If you have TMobile as a provider they use the 1900 MHz freq as their "primary" band and if this band is weak, not available (due to use by other customers), or not available due to lack of coverage within thier system then they switch to the 850 MHz band as a secondary customer. If you have a Serene and you pass into one of these areas, your call will immediately be dropped because the phone does not have an 850 MHz capability. Likewise, AT&T use the 850 MHz band as one of thier their "primary" bands and with the Serene you can (depending on location) often be using their "secondary" back-ups, e.g. the TMobile system. In this situation, as you are secondary, coverage is very questionable because the TMobile customers have prioroty over the bandwidth. This is what I learned in speaking with TMobile, AT&T and the B&O Product Specialst.
The bottom line is that coverage with a Serene is highly dependent on your use area and a detailed analysis is in order. You might ask to borrow a live phone from your B&O store to determine how well it works for you. I did this and decided the coverage was too "sketchy". Too bad because for all of the reasons given above, the Serene is a great phone with nice B&O design characteristics.
Seek simplicity and distrust it. Alfred North Whitehead
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Serene, Serenata, Nokia, Ericsson, Samsung, Motorola... All rubbish compared to iPhone. It's a matter of opinion I know, and as a Finn I would wish nothing more than a Nokia phone on par with the iPhone. I understand the idea of getting a B&O phone, if it was a B&O phone, and not a Samsung. If it had the goods to back-up it's price.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
jk1002
- Boston USA
- Posts 1,620
The iphone is in its own little world. If you want to use it as a phone only there is no point. Someone here called the Serene a Dress Phone which in my opinion nails it. The market is there, Tag Heuer has one, Vertu has is an entire brand. They just need to get rid of that samsung logo for christ sake.
TWG
- Joined on 04-17-2007
- Germany
- Posts 950
Is there any option to send custom ringtones via Bluetooth or does the phone simply NOT accept them? Did anybody try this out? Any option to change the display orientation "forever"?
Oh, and please do not compare the Serene with a Vertu ;-)
There are worlds of quality between the Samsung plastic phone and a Vertu or Tag Heuer.
Evan
- Ohio | USA
- Posts 2,601
bayerische
- Helsinki, Finland
- Posts 3,593
Vertu = Nokia... But they understood to leave the Nokia logo out.
-Andreas
TWG
- Germany
- Posts 950
bayerische:Vertu = Nokia... But they understood to leave the Nokia logo out.
Yes, you're right. And with that Vertu-Logo they suddenly understand about real quality  And as mentioned right above: The Serene still stands out from the crowd because of its design. That's the good point :-)
