1st March February 2012
Latest post 12-18-2008 4:39 PM by kawo. 6 replies.
12-17-2008 2:14 AM
kawo
- Joined on 04-17-2007
- Posts 516
Panasonic BlueRay BD 35 - where is the IR receiver?
I have real trouble to get the BD35 to work, unfortunately I am unable to locate the IR receiver to control the player with my BS3 & PUC. Any idea where it is? Thanks Karsten
_________________________________________________________________________
BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
Alex
- Joined on 04-16-2007
- Bath & Cardiff, UK
- Posts 2,990
Re: Panasonic BlueRay BD 35 - where is the IR receiver?
It's on the right hand side of the disk tray, but to the left of the lettering. I think it's *just* to the left of the first logo on the top.
FWIW, I've found the 'Generic Panasonic Blu-Ray option works fine in the PUC controller.
Weekly top artists:
kawo
- Posts 516
Alex, great thank you! Now it works. Unfortunately I have only the PUC for the Panasonic DMP-BD10 which works great execept power off function. Do you have any problems with power Off or On with your PUC? Karsten
Alex
- Posts 2,990
I can't say I've ever tried powering down the BD35 through the PUC controller. TBH, it's not something I'd worry about, although it's something you might. The last time I checked (which was a few weeks ago), the BD35 wasn't on the PUC controller list, so a software update from your dealer would do nothing.
I'll try and find out if anything is happening for you!
Weekly top artists:
kawo
- Posts 516
Great, thank you very much! (power on works with PUC, just checked this)
beobuff
- Joined on 04-21-2007
- Posts 59
kawo: Alex, great thank you! Now it works. Unfortunately I have only the PUC for the Panasonic DMP-BD10 which works great execept power off function. Do you have any problems with power Off or On with your PUC? Karsten-
The power-off function works just fine with my BeoSystem 3, but it doesn't work with my BeoVision7. I am using the exact same Panasonic BD10 driver on both units to control my two BD35s. Interestingly enough, I have exactly the same problem using the Toshiba HD-DVD A20 driver to control my two Tosh A35s: power-on works with both the BS3 and the BV7, but power-off works only on the BS 3. It would seem that the fault lies not with the two PUCs, but rather with the BV7.
kawo
- Posts 516
Interesting! I also have a Panasonic DVD Recorder attached to the same BS3, Power Off and On works without any problem
Page 1 of 1 (7 items)
