Latest post 12-29-2008 5:51 AM by Beogen. 9 replies.
Page 1 of 1 (10 items)
  • 12-16-2008 4:13 PM
    Latest firmware 1.40a and Config Tool 1.30
    I got my new Beo5 today, firmware is 1.40a which refuses to download Configuration Files created with Config Tool v1.30.
    Anybody knows a solution to this problem?
    Filed under:
  • 12-17-2008 12:53 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Latest firmware 1.40a and Config Tool 1.30
    There is a new SW version 2.20 of the Config Tool.
    Quim
  • 12-17-2008 4:06 AM In reply to
    • TWG
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Is there a "changelog" what's different in the new firmware and in the new config tool?
    Perhaps it solves some problems (like mine) where  the Beo5 refuses to get the configuration ...:-(
  • 12-17-2008 4:23 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    I noticed new firmware doesn't send the commands of third party xml files. I hope it's my fault, but it doesn't look well.
    Quim
  • 12-17-2008 4:32 AM In reply to
    Does the software add support fot Beosound 5/Beomaster 5?
    p.
  • 12-17-2008 4:38 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    PhilLondon:
    p.
    Yes, Beomaster 5 is in B&O Products list.
    Quim
  • 12-17-2008 4:45 AM In reply to
    I wonder if the PCG has been updated as well...
    p.
  • 12-17-2008 10:58 AM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Quim43:
    Apparantly there is an issue with the FW 1.40 and the 3rd party XML files, we are looking into it right now.
    In the meantime, people who upgrade to tool 2.20 and fw 1.40, will NOT be able to use the XML files from the 3 party tool, and you cannot go back, once you have FW 1.40.
     FW 1.40 needs config tool 2.20, and cannot be serialized with 1.30.
     So if you rely on the 3rd party tool, then don't upgrade just yet.
    /Weebyx
  • 12-17-2008 3:13 PM In reply to
    • ujn2
    • Not Ranked
    • Joined on 03-27-2008
    • Posts 17
    TWG:
    I would also like to know...
  • 12-29-2008 5:51 AM In reply to
    • Beogen
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Belgium
    • Posts 135
    Improvements
    New B&O products added:
    • DVB-HD.
    • BeoVision 7 no DVD.
    • Preparation for BeoSound 5.
    Engine improvements, less or not visible to the user:
    • Major changes in the internal architecture of the tool software.
    • Serializer efficiency is improved in terms of binary size, leaving more space for e.g. logos.
    • Error corrections on both tool and firmware improving support for 3-party IR.
    Errors corrections:
    2 A-rated errors, 23 B-rated errors, 20 C-rated errors, and 16 D-rated or not classified errors. Totally 61 errors.
    Emphasised corrections:
    080905          Not able to change speaker mode in N.MUSIC/N.RADIO.
    085485          "Text" button missing within Text menu on DTV and VMEM source.
    085763          AV-sources not available in link room.
    085399          MENU not sent with link bit on bl3500 in option 4.
    084134          If you change the name of the speaker modes they no longer work.
    076113          Serialization error when using BC 2-MKII with BeoCenter 6 in the same zone.
    082532          Error deleting delays in macro.
    085293          No DVB-T for BeoVision 8.
    081020          Imported configuration is not stored correctly.
    082540          V.MEM separated into V and MEM.
    076541          Serialization failed when a channel number is 0 or bigger than 65535
    078833          Serialization error when moving /TV/ button.
