Latest post 12-16-2008 11:57 AM by Alex. 2 replies.
Page 1 of 1 (3 items)
  • 12-16-2008 11:53 AM
    • gce123
    • Not Ranked
    • Joined on 12-16-2008
    • Posts 1
    3500 as passive loudspeakers?
    First posting on here so please go easy on me - fairly new to B&O products.
    I am desiging a new (non-B&O) multi-room music system for a client with centralised amplification and loudpseaker cabling running to all zones.
    As the client has a 3500 stored in a cupboard he has asked if it could be re-used for one of the zones.
    I think I already know the asnwer to this, but just wanted to check to see if there is any way that a 3500 could be used as just passive loudspeakers fed from an amplified loudspeaker level feed.
    Thanks for any help you can give.
  • 12-16-2008 11:56 AM In reply to
    Re: 3500 as passive loudspeakers?
    (sorry I had made an answer but thought it was the 4500...) I do not think the 3500 can be used as a passive speaker.
  • 12-16-2008 11:57 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    It's possible but it wouldn't sound very good! The 3500 relies on an EQ curve to produce a good response. You could wire it up if you wanted, but he would probably be better off selling the 3500 and buying a good set of passive speakers instead.
    Just out of interest, why the whole 'centralised amplifiers' idea?
     Weekly top artists:
