Latest post 12-25-2008 10:13 AM by Russ. 4 replies.
Page 1 of 1 (5 items)
  • 12-14-2008 10:50 PM
    • beotex
    • Not Ranked
    • Joined on 04-20-2007
    • USA
    • Posts 32
    Latest Beosystem 1 software?
    Anyone have the lastest list of controlled devices? I just ordered Verizon Fios TV and I'm hoping it will be supported.
    Thanks.
  • 12-15-2008 11:32 AM In reply to
    Re: Latest Beosystem 1 software?
    I have the Excel file with the supported device list for the latest Beosystem 1/ Avant software. IM me with your email address and I will be happy to send it to you.
  • 12-18-2008 8:37 PM In reply to
    Would be interested in that list as well.  Out of curiosity what is the current software version for the BS1/Avant software?
    BeoVision 4-50 MkII, BeoSystem 1, Zektor Switch, DTS box, BeoLink Passive, BeoVox Cona, BeoLab 1, BeoLab 3500, BeoLab 6000, BeoLab 4000, BeoLab 4, BeoLab 3000, BeoMedia 1, BeoMaster 5, BeoSystem 3 Type 9621
  • 12-18-2008 10:39 PM In reply to
    • expoman
    • Top 500 Contributor
    • Joined on 04-17-2007
    • United States
    • Posts 222
    Mine was updated to 4.7 L recently.  i think that is the latest.
  • 12-25-2008 10:13 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    BeoTex,
    Both Motorola and Scientific Atlanta are lazy/efficient in that they don't often change their IR codes and software.  Assuming that you have a fairly recent PUC installed (3-4 years old), chances are that you can find a device on the ist from the same STB manufacturer and it will work just fine.
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
