Hi Mico,
If you find noone with the xml file you can create it yourself. Just download the XML Generator tool from here, then you can use the Pronto information from the Pioneer US web site to create the XML file. I am currently doing this for my Pioneer DVD Player, I hope I can even use the Beo5 to remove the region code.
Cheers,
Frank
