Latest post 01-01-2009 5:46 AM by Craig. 6 replies.
Page 1 of 1 (7 items)
  • 12-13-2008 3:26 PM
    Beolink 1000 - Questions ????
    Can anyone tell me where or how to get to the menu key on my Beolink1000?
    Not sure what model it is but I'm trying to "tune" in stations to my Avant using the 1000
    The remote doesn't have a "menu" key.................
    Can I tune in the Avant with this remote, if so how ?
    Alternatively, can I manually tune the Avant, if so how?
    Cheers,
    Steve
  • 12-13-2008 3:40 PM In reply to
    Re: Beolink 1000 - Questions ????
    You must have a Mk1 or 2 Beolink 1000
    So MENU = SHIFT, TEXT
    GO = PLAY
    Regards Graham
  • 12-13-2008 4:49 PM In reply to
    Thanks for that ............. I really appreciate it !! - Top Man
  • 12-14-2008 8:54 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Here are some more key combinations which may be of use to you
    Beo 4    Beolink1000 MkI & II    Beolink 1000 MkIII & IV
    [red]        [SHIFT] [<]                   [SHIFT] [\/]
    [blue]       [SHIFT] [>]                  [SHIFT] [/\]
    [green]     [SHIFT] [<<]                [SHIFT] [<<]
    [yellow]    [SHIFT] [>>]                [SHIFT] [>>]
    [MENU]    [SHIFT] [TEXT]              [MENU]
    [LIGHT]    [SHIFT] [LINK]              [LIGHT]
    [GO]        [PLAY]                          [PLAY]
    [DTV]      [SATELLITE]                  [SAT]
    [DVD]      [SHIFT] [CD]                [SHIFT] [SAT]
    [PC]         [SHIFT] [STORE]           [SHIFT] [STORE]
    [DVD2]    [SHIFT] [V.TAPE]           [SHIFT] [V.TAPE]
    [V.AUX]    [SHIFT] [TV]                 [SHIFT] [TV]
    [A.AUX]    [SHIFT] [RADIO]           [SHIFT] [RADIO]
    "N.RADIO"    [PHONO]                   [PHONO]
    "N.MUSIC"    [SHIFT] [A.TAPE]       [SHIFT] [A.TAPE]
     Chris
  • 12-15-2008 8:54 AM In reply to
    • majand
    • Not Ranked
    • Joined on 02-26-2008
    • Helsinki
    • Posts 72
    • Gold Member
    How about other way around, using Beo4 as Beolink1000 with, for example, MX5500?
    I guess, need to find at least sound, picture, store etc.
    Pekka
  • 12-31-2008 1:49 PM In reply to
    • TEL
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Berks U K
    • Posts 92
    Do you have same info for Beolink 5000 and Beolink 7000 ?
    TEL
  • 01-01-2009 5:46 AM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    majand:
    Pekka
    You can use a Beo4, but a BL1000 works much better and easier with an MX5500.
    CraigSmile
