Latest post 12-13-2008 5:53 AM by frankie. 4 replies.
Page 1 of 1 (5 items)
  • 12-11-2008 6:47 PM
    • frankie
    • Not Ranked
    • Joined on 12-11-2008
    • sevilla
    • Posts 12
    • Silver Member
    problems with beogram 4004 arm
    good evening beofans , my name is frankie and i`m a new forer .
    I tell , my problem with  beogram 4004 , fours days ago i bought it from U.S (117 volt) send by air mail , i conecct  with  125 volt transformer in spain.
    When i touch PLAY ,the arm move to the begining disc and the sound is ok , but the arm no move then at a few minutes the disc jump .
    If i touch < or > the arm move across the disc with no problem.
    Please if anybody Know solve the problem ,i would be very thank . please help me.
    I´m sorry for my bad english.
    Regards from spain.[:'(]
    Filed under:
  • 12-12-2008 7:21 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: problems with beogram 4004 arm
    Probably a burned lamp at the tracking sensor, sitting at the foot of the tonearm carriage.
  • 12-12-2008 11:01 AM In reply to
    • frankie
    • Not Ranked
    • sevilla
    • Posts 12
    • Silver Member
    thanks Dillen for your answer , i test this lamp , and said you something.
    thanks and regards.
    Frankie.
  • 12-12-2008 8:26 PM In reply to
    • frankie
    • Not Ranked
    • sevilla
    • Posts 12
    • Silver Member
    Hello Martin :
    I have test the lamp on the Dial and its ok , when touch play the arm go to the record position and lower  and if touch second time play the arm goes to the finish record and come ,the dial have two bands shorts and two bands long for position on the record and the lamp read it.
    I has probe to put a paper between the bulb sensor and the dial and then no read and no stop the arm and the arm recognize 33 or 45 rpm record.
    The arm is ok in < > slow tracking and the << >> fast tracking in manual operation but one time the arm position in the begining of disc and the arm lower over the disc , the arm is stop, the lamp of the second arm is on.
    Thanks and regards.
  • 12-13-2008 5:53 AM In reply to
    • frankie
    • Not Ranked
    • sevilla
    • Posts 12
    • Silver Member
    Problem Solved by Dillen.
      Thanks Party!!!
