Hello.  I have just purchased a fantastic 7-40 MKII to replace my Avant DVD and I am trying to set up a Samsung Sky HD STB! I have connected via the DVI with a HDMI-DVI converter and am using RCA for sound (will use digital when I get the connectors).  I get picture and sound OK but cannot control the Sky HD with the B&O remote.
My questions are:
1. Which option should I use as the STB controller (the Sky HD is not listed)?
2. Do I need a SW update to enable the Samsung Sky HD Bow?
3. Where do I place the IR blaster on the Sky box?
Any Help would be appreciated.
