Hi Chris,
Thank you for your reply..
It is very interesting to see different ideas and opinions. Indeed the CX100 lacks some bass (I have 5 of these in my home theater with a small woofer... sounds good enough for movies in this setup.) so probably not the best choice for music, I must agree.
I have owned and restored RL60s before, so I know what I am in for ....the sound is reasonable good.
Indeed the beomaster 5500 is very similar to the 5000. I never consided the S series myself as I never heard (or seen) one before.. I have no problem refoaming and cap replacing as long as I can get hold of the right caps and foams. Thank you for the Dillen tip!
As this is not an urgent project but more of a pet project, I am keeping my options open and I will sure check if I can find some S series speakers. If only to listen how they sound. The final decision will also depend on what is available here in (right now .. extremely snowy) Canada.
Regards,
Oliver
