Latest post 12-08-2008 6:11 PM by cjscos. 4 replies.
Page 1 of 1 (5 items)
  • 12-08-2008 5:18 PM
    • cjscos
    • Not Ranked
    • Joined on 12-08-2008
    • Posts 4
    ouverture and 2500 whats the difference?
    as above really... i beleive the ouverure has a master link (not really clued up on these things) but what is the difference between the two as they seem to look the same but according the this website they are different....
     will it say 2500 or ouverture on the back?
    any help appreciated
  • 12-08-2008 5:28 PM In reply to
    Re: ouverture and 2500 whats the difference?
    The major difference is that the Ouverture has Masterlink the 2500 does not.
    The 2500 is 2 way remote the Ouverture is not
    It either says Beocenter 2500 or Beosound Ouverture on the back. (In N America the Ouverture is Beosound 4000)
    Regards Graham
  • 12-08-2008 5:58 PM In reply to
    • cjscos
    • Not Ranked
    • Posts 4
    many thanks for your reply. what are they worth with a stand in mint condtion?
  • 12-08-2008 6:05 PM In reply to
    Prices obtained are many and various. Depends who is doing the buying and selling.
    Generally the 2500 is worth less than the Ouverture
    Regards Graham
  • 12-08-2008 6:11 PM In reply to
    • cjscos
    • Not Ranked
    • Posts 4
    many thanks for you help.
