Latest post 12-09-2008 5:06 AM by stotty1111. 7 replies.
Page 1 of 1 (8 items)
  • 12-08-2008 4:22 PM
    Help required for a new member please
    I have just purchased a rather nice Ovuerture Stereo with the matching 2500 Active speakers if any kind soul can answer these questions Id appreciate it
    looking in the instruction manual it shows that the Stero can be connected with three leads using th same current these are Female and male ( what I call tape lead connectors ) mine just has three tape leads with three seperate plugs one for the main unit and one each for the Speakers
    Were can I get these leads from ie. two of the female to male leads
    My second question is
    How do you remove the speaker Grills ( I aint got a clue ) and likewise for the glass panels to clean behind, im frighterned of smashing the glass pulling to hard , so have yet to attempt it
    And FInally is there a supplier who makes an aluminium insert to cover over the tape recorder bit as I dont use it
    Oh I forgot " Is it possible to turn the lights off to save energy
    Cheers Eddy
  • 12-08-2008 4:31 PM In reply to
    Re: Help required for a new member please
    May I ask where you bought it from/why isn't the original owner assisting you?  Was it placed in a Beosystem bracket originally?
  • 12-08-2008 4:36 PM In reply to
    At radioogtveksperten.dk or +45 40165521
    Yes. Turn of the power....Big Smile
    Regarding the grills; it depends. Are the alu covers or som form of fabric? The glass pulling i would go to a shop and get demonstrated.
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
  • 12-08-2008 4:37 PM In reply to
    The original owner sold me it , I phoned him to ask about removing the doors he said you gently pull them outwards when open im not to keen on pulling them as I may break something, they dont need cleaning at the moment.
    If you could help with the other questions as the instruction booklet suggests you can attach three cables from Speaker to speaker then speaker to amp and then from the speaker to the mains.
    id like to get two if these special two ended leads one with and in and one with an out end.
  • 12-08-2008 4:40 PM In reply to
    thats exactly what im looking for to cover the tape section although id like one which is the same colour as the cd clamp
    the speaker grills are cloth
  • 12-08-2008 4:47 PM In reply to
    You seem to have a wiring diagram for the unit used in a bracket which accomodates the speakers - individual power leads and speaker leads will do.
    When the power is off detach the doors by gently easing them from the outside edge towards you - exerting pressure inwards or towards the centre of the stereo.  You perhaps should have bought a 2300 or 3000 if you don't want the tape mech.
    Hope this helps
  • 12-08-2008 5:03 PM In reply to
    You need a short cable set which your dealer should be able to order still. Comprises two short powerlink cables and two short mains leads. Was designed for using the system in a wall bracket with only one mains connection for the whole system and the other cables hidden in the bracket.
    Regards Graham
  • 12-09-2008 5:06 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    powerlink cables - try iconic b/ham uk do a google seach can't find their address at the moment he has the 4 lead set on offer for £30 + p&p - you will just need a long power lead from elsewhere or you may already have one
    glass removal - place machime on soft and thick material , mine came off by pulling outside edges gently outwards the clips then spring free(ie side edges!)
    speaker frets - 2 x blunt knives gently insert in middle of top and bottom edges and gently lift the frame outwards - should spring free(knives inserted about 10 - 12 mm (1/2")
    tony s
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
