Hi all
Sat here wondwering if there is any gain in removing the module- I have a spare rear central cover?
Will the set then respond to the satellite command of the bl1000 or beo4? - the set is an early example, 3383 sw1.0(i think) with no listing of satellite against the av1/2 scarts
Or, will i have to replace the eprom to achieve this function?
Is it worth the hassle or do i live with the problem and program av2 to respond to a spurious label ie vcr2 etc?
Its Monday, my brain hurts already, but any suggestions greatfully received!
Sorry if this has been asked before but i ve tried to locate the topic if covered earlier!
salut
Tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
