Hi Beolit and welcome to Beoworld !
I have suitable lamps but I cannot tell you if replacing the lamp alone will make the Beogram play again. The lamp is an essential part of the whole system and you really cannot diagnose any further before a new lamp has been mounted. Replacing the lamp is not the easiest task but if you have basic soldering skills and electronic tools, you can do it.
