Latest post 12-07-2008 9:03 AM by propaganda. 2 replies.
Page 1 of 1 (3 items)
  • 12-07-2008 12:59 AM
    • davideg
    • Not Ranked
    • Joined on 08-13-2008
    • Rimini Italy
    • Posts 3
    PS 3 can be controlled?
    Dear all,
    i am planning to buy the PS3, more attracted from the Blue Ray than the games, and i would like to know if is possble to command it with my beo5, can somebody hep me?
    David.
  • 12-07-2008 2:24 AM In reply to
    Re: PS 3 can be controlled?
    Hi
    Search the forum and you will find a lot of info regarding PS3 an B&OYes -  thumbs up
    Start here: http://beo5.beoworld.org/Downloads.htm
  • 12-07-2008 9:03 AM In reply to
    Yes it can be controlled by the Beo5, BUT you need an NYKO Bluwave remote controller (I think templates for another controller are also available), then you need to use the provided template available on this forum to allow the Beo5 to speak to the NYKO USB dongle. To be honest if you have BV7 mk3 , are not really into the PS3 games, and can wait till early next year when B&O will bring out their own BluRay device then I would wait for that for better integration. However Bluray is excellent on the BV7 connected to a PS3 if you really cannot wait.
