Latest post 01-14-2009 4:02 PM by Craig. 8 replies.
Page 1 of 1 (9 items)
  • 12-06-2008 5:49 PM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beocenter 2200 cassette problems
    How do you test a playback head? At the moment I ma trying to fix a Beocenter 2200 I was given. Last night I fitted a new set of drive belts (Thanks MartinWink) Now I can only get sound out of the Left channel. All othere sources work ok and I have swapped the two connectors over that come form the playback herad. This causes no sound in the Right channel instead. The wiring is fine between the head and the connectors. Although I always thought when a head went down on one channel you got strange ohm readings accros the head. Tested both channels and got a readings of 212.3 and 212.5 Ohms.
    CraigSmile
  • 12-07-2008 5:54 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 2200 cassette problems
    Maybe you pulled a cable partly off somewhere ?
  • 12-08-2008 1:33 PM In reply to
    • Craig
    • Posts 4,855
    Well I did think they may be a problem with the cables. Tested them from the plug to the head and there are no problems as far as I can tell. Where does the middle wire from each plug go? As there are three wires at the plug but only two go to each channel of the head.
    CraigSmile
  • 12-08-2008 4:46 PM In reply to
    • Dillen
    • Posts 5,008
    The center lead is ground.
  • 12-15-2008 3:19 PM In reply to
    • Craig
    • Posts 4,855
    Ok well I have sorted out the problem with the head. Chris(Medogsfat) supplied with one had. Now I have noticed that the cassette rewinds when I try to fast forward. It rewinds ok whn I press rewind though. As far as I can tell I have the belts on correctly. This is the ast problem I need to sort out. Any advice is greatly appreciated.
    CraigSmile
  • 12-30-2008 6:31 PM In reply to
    • Craig
    • Posts 4,855
    Bump, still rewinds on Fast Forward and Rewind. Any ideas anyone?Laughing
    CraigSmile
  • 01-14-2009 12:41 PM In reply to
    • Craig
    • Posts 4,855
    Craig:
    CraigSmile
    Well I am going to bump this one more time. If I can't sort it out I will just list it on Ebay as it is.LaughingLaughing
    CraigSmile
  • 01-14-2009 12:57 PM In reply to
    • Dillen
    • Posts 5,008
    Strange fault indeed. Can't you find out whre the commands come from ? Surely something must be shorted somewhere.
  • 01-14-2009 4:02 PM In reply to
    • Craig
    • Posts 4,855
    Dillen:
    Looks like I will have to try to get to the PCB with the control switches on. Looks like an awkward job to say the least.Sad
    CraigSmile
