Hi all,
Just a simple question does anyone know if the beomedia 1 will work with an AppleMac OSX operating system
if you mean that you want to replace operating system inside beomedia 1
the answer is not possible, but if you want to have mac client computer in the same network it would work
http://tv4play.se/nyheter/lokala_nyheter/halland?videoId=1.645093
Beomedia 1 has its own operating system, you cannot change it. However you need to transfer the music to it. For this you can use a mac or a PC.
p.
Mac, iPad & iPhone Apps: Beoworld, LinkPlayer, LinkRemote, Story Mouse, The Emperor's New Clothes
I don't think Applemac1 wants to run OS X on the actual Beomedia itself. Yes, the BeoMedia will work with a Mac through BeoConnect, but it won't play iTunes-protected files. What do you want to use the BeoMedia for?
Weekly top artists:
