1st March February 2012
Latest post 02-03-2009 3:58 PM by Alsfeld. 12 replies.
12-04-2008 4:03 AM
timhanna
- Joined on 11-28-2007
- London
- Posts 602
BV7-40 MK3, red standby LED blinks
It first started recently, 30secs after switching off the TV the red LED starts blinking. I do have a PIN code attach to the TV, but the power was never disconnected. Does anyone know what this might be? Thanks, Tim
stefan
- Joined on 04-16-2007
- 200 miles from Struer
- Posts 1,733
Re: BV7-40 MK3, red standby LED blinks
Maybe a Masterlink problem. Disconnect the mains for about one minute and reconnect. Everything should be fine now. Stefan
timhanna
- London
- Posts 602
Hi and Thanks for the reply Stefan. I did, and it did go away, ok, it wasnt 1 minute... but the thing is that a couple days later it happened again... Ill try it for a minute today... strange...
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
Hi Tim I think it can be a software issue. Look what the new software fixes: Build 433 (H8 SW 5.02). Support for DVB-HD. Teletext in P-P gives TV+TV. Intermittent loss of the PUC Table. New features: - Support for DVB-HD (only released in some markets).
- A of this SW release, the TV menus are black instead of grey and are
placed on the left side of the screen. There is no change in meno
structure and function.
Symptom: - Teletext in P-a-P gives TV + TV
- Intermittent loss of the PUC Table
- Standby led is blinking <-----------------
- ACM bar opticallt too narrow
Cause - The M2 porcessor was disconnected due to illegal communication. The problem is now fully solved.
- A powering down problem in the DVF-module. Error not seen on build 433 during test.
- When
implementing a larger screen, the Auto Color Management bar became a
bit too narrow. This does not influence the Automatic Colour Management
function.
Solution: To all above problems, please update to build 433. Compatibility: The
build is "internally compatible". This means that you must use the
entire build when updating the software, do not mix parts of the
software with other builds.
Weebyx
- Joined on 06-30-2008
- Denmark
- Posts 321
timhanna: It first started recently, 30secs after switching off the TV the red LED starts blinking. I do have a PIN code attach to the TV, but the power was never disconnected. Does anyone know what this might be? Thanks, Tim
I reported the blinking LED to my dealer months ago, and with the new 5.02 SW it should be solved. ************ Build 433 (H8 SW 5.02). Support for DVB-HD. Teletext in P-P gives TV+TV. Intermittent loss of the PUC Table. Symptom: - Teletext in P-a-P gives TV + TV
- When implementing a larger screen, the Auto Color Management bar became a bit too narrow. This does not influence the Automatic Colour Management function.
Solution: To all above problems, please update to build 433. ********** /Weebyx
Weebyx
- Denmark
- Posts 321
Quim43: Hi Tim I think it can be a software issue. Look what the new software fixes:
Damn, you beat me to it :) /Weebyx
timhanna
- London
- Posts 602
Guys, I really thank you all for it! Ah, on the phone again to get this mess sorted!
KingOfSnake
- Joined on 02-07-2008
- Posts 359
Tim, sorry to offer a non-technical and software related solution, but I have experienced this problem with low voltage lighting and electrical inteference from other IR emitting sources. Do you have any nearby?
timhanna
- London
- Posts 602
Hi KingOfSnake, Thanks for your response! Well, I do have a cabinet full of: an STB box, PSTN base, router and something else, but not light sources to be honest... :S Im in the process of arranging a visit by b+o to upgrade the software, under warrenty, mmmaaaaybe it will fix it. Thanks agian
timhanna
- London
- Posts 602
Hope everyone had a great Xmas! Sorry, for not posting the solution, the answer is to upgrade to SW 5.02, all, working great.
gordongofer
- Joined on 02-24-2008
- Posts 13
Yes, get 5.02 installed. I got a BV7-40 last summer and to be honest, i was disappointed with both it, and the Beo5.( used with a sky box). I have now had the update from SW3.24 and everything works well. Its like a new TV. Frankly, I'm a bit p***ed off that Beoworld was the only place I found out about the software upgrade, and even then had to twist my dealers arm.
StUrrock
- Joined on 02-04-2008
- Cambridgeshire
- Posts 219
gordongofer: I have now had the update from SW3.24 and everything works well. Its like a new TV. Frankly, I'm a bit p***ed off that Beoworld was the only place I found out about the software upgrade, and even then had to twist my dealers arm.
Not surprised you are br*wned off! It has been a known issue for some time now. Who is is the dealer?
Name and shame
Alsfeld
- Joined on 04-20-2007
- Posts 91
I have the same problem with my Beovision 9, SW: 3,1.
After 30secs sometime the red LED strats blinking. When I press the red turn-off button it stops blinking. Sometimes I have to repeat this procedures two to three times.
Should I change the software? Does the blinking heard the TV? - I really don't care if the red LED blinks or shines.
Page 1 of 1 (13 items)
