Latest post 12-05-2008 3:50 AM by bus55. 3 replies.
Page 1 of 1 (4 items)
  • 12-04-2008 3:29 AM
    • bus55
    • Not Ranked
    • Joined on 12-23-2007
    • Posts 10
    headphone issue
    I have a beosystem 5500 and when I plug in my headphones in the amp the sound is heard through both the headphones and the s55 speakers. Can I set it up so I only hear it through the headphones.Thanks and appreciated.
  • 12-04-2008 4:03 AM In reply to
    Re: headphone issue
    bus55:
    It should happen automatically, but only for speakers connected to the first speaker outputs (the upper sockets in the rear panel). Do you perhaps now have them in speakers 2?
    -mika
  • 12-04-2008 5:42 AM In reply to
    Re: headphone issue
    I agree. Do the speakers mute when you press mute on the Beomaster? If not, then you are using speaker 2. The problem may be because Speaker 1 has a problem - the mute circuit relay commonly plays up on these meaning you get no output or only one channel.
  • 12-05-2008 3:50 AM In reply to
    • bus55
    • Not Ranked
    • Posts 10
    Re: headphone issue
    Spot on thanks heaps.All good
