Latest post 12-18-2008 8:56 PM by Hildebrand. 1 replies.
Page 1 of 1 (2 items)
  • 12-03-2008 9:06 PM
    Parts for the Beolab 3500 speaker [pre-1999]
    I have moved and lost parts to this speaker, and one of the fabric panels is damaged. I am very low tech, so please help.
    I can't find what plugs, cables etc go with this speaker, or the pedestal for using it on a table. How do I locate and buy these? Also, is there a way to fix the panel or find a new one?
    Thanks so much for your help.
  • 12-18-2008 8:56 PM In reply to
    Re: Parts for the Beolab 3500 speaker [pre-1999]
    Any dealer should be able to help you out with that.  Here's some part numbers though for you...
    BeoLab 3500 MKII Service Manual
    3451470 Cloth front, dark grey
    3451472 Cloth front, silver
    3451244 Cloth front, black
    Optional Accessories
    Wall bracket Type 1607 - 3031302
    Wall bracket 3031235
    Wall plate 3031333
    Table stand Type 1606 - 1160611
    Cable cover 2560276 (10 pieces x 2.5m)
    In terms of cables you should have a Mains cable for power and then depending on your setup either a ML (MasterLink Cable) or a MCL cable.
    BeoVision 4-50 MkII, BeoSystem 1, Zektor Switch, DTS box, BeoLink Passive, BeoVox Cona, BeoLab 1, BeoLab 3500, BeoLab 6000, BeoLab 4000, BeoLab 4, BeoLab 3000, BeoMedia 1, BeoMaster 5, BeoSystem 3 Type 9621
