Latest post 12-15-2008 6:37 AM by fridsten. 6 replies.
Page 1 of 1 (7 items)
  • 12-03-2008 5:35 AM
    Connecting CX speaker to my PC ??
    Having an old pair of B&O CX loudspeakers I would like to use with my PC - anyone got some info on what I need in terms of cableadaptors and amplifiers to make it work ??
     Thanx !
  • 12-03-2008 3:29 PM In reply to
    Re: Connecting CX speaker to my PC ??
    I use CX100s with my Mac. Minijack from the audio out to the tape 2 input on a Beomaster 5500 . CXs attached to 5500. Excellent sound!
  • 12-03-2008 5:17 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    When I had CX100's as my PC speakers, I used a Beomaster 2000. Sounded very good as Peter has already said.
    CraigSmile
  • 12-03-2008 5:24 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Me? I have PC to Beoport to Beomaster 3000 to Redline 45s. It's great!
    Poor me, never win owt!
  • 12-05-2008 6:26 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    I'd go with Peter on this one - beomaster 5500 is a truly excellent amp with tons of input connections which are duplicated in RCA/phono & DIN. It is remote controllable with a beolink 1000 or the combersome MCP5500 - which you would need to adjust volume etc.... If remote control isn't a problem then a beomaster 5000 has the same inputs and has manual buttons hidden under a drop down flap and is probably a better amp although most will be in need of a bit of TLC to get back to 1000% working order - these can also be remotely controlled with either the terminal 5000 or MCP5000. Both are very robust tuner/amps though and seldom break down.
    Chris.
  • 12-06-2008 5:17 AM In reply to
    • Ben
    • Top 500 Contributor
    • Joined on 12-28-2007
    • Taunton, UK
    • Posts 131
    • Silver Member
    Remember that you can use another brand of integrated amplifier/receiver to power these speakers, doesnt have to be B&O.
    I have an old 55wpc Technics receiver hidden away powering the CX100's next to my monitor, works great, and it only takes a reach under my desk to alter the volume.
  • 12-15-2008 6:37 AM In reply to
    • fridsten
    • Joined on 04-17-2007
    • Stockholm, Sweden
    • Posts 167
    Ben:
    Exactly my opinion. If I was to connect a pair of passive B&O speakers to my computer, I'd definately consider the Sonic T-Amp.
