Latest post 12-02-2008 8:09 AM by Razlaw. 5 replies.
Page 1 of 1 (6 items)
  • 12-01-2008 5:02 PM
    • brhnz
    • Not Ranked
    • Joined on 11-26-2007
    • Posts 9
    • Silver Member
    BSYS3 & Non B & O Active Sub - Help
    Hi Team
    Is it possible to run a non B & O Sub off the SUB out ? , Did try it with 8-pin-Dinn to RCA but could not configure the BS3 due to not been able to save the settings. Can any one discribe how they have done this before. ?
  • 12-01-2008 7:36 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: BSYS3 & Non B & O Active Sub - Help
    I would think that setting 'Sub' to beolab 2 and saving the settings ought to work.  What happened when you did that?
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 12-01-2008 8:53 PM In reply to
    • brhnz
    • Not Ranked
    • Posts 9
    • Silver Member
    I thought so to. Seems that when i use a DIN - RCA lead the BS3 does not want me to save the settings. Instead it refuses to save unless I set sub A-B ( i only want one ) . Really odd. BS3 is on latest SW . I believe there is data been sent down the PL from the BL2 to the BS3 that I cant recreate  .
    Strange :)
  • 12-01-2008 11:35 PM In reply to
    We have a Velodyne sub connected to our BV7. In the settings it does appear that there are two subs. It works fine.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 12-02-2008 12:38 AM In reply to
    • brhnz
    • Not Ranked
    • Posts 9
    • Silver Member
    And you are using a standard 8pin DIN to RCA lead ? Do you know how it is wired ?
  • 12-02-2008 8:09 AM In reply to
    I am not sure what kind of cable it is. It has a powerlink connector into the BV7. The powerlink connector then has two wires coming out of it each a few inches long with a single plug on the end. I think those are RCAs. Those two plugs then connect to two others that go into another wire about 10 feet long that runs to the Velodyne. At the end of that wire is a single plug, that is somewhat larger. That single plug connects to its mate that then has two short wires coming out of it a few inches long that each have a plug at the end (RCA?) which are both plugged directly into the Velodyne. If you need more detail I can look more closely later, only have time this morning for a quick look.These are the same connectors I used with our Avant for several years. I have not really looked at the cables for many years as the dealer merely disconnected the Avant and reconnected to the BV7 when it was delivered. In the Onscreen menu the first speaker is set to Beolab 2 and the second speaker says the same although it is dimmed out and can not be changed.
