Latest post 12-02-2008 4:40 PM by Beogen. 5 replies.
Page 1 of 1 (6 items)
  • 12-01-2008 1:42 PM
    • Beogen
    • Top 500 Contributor
    • Joined on 05-12-2007
    • Belgium
    • Posts 135
    AV DTV function
    Hello,
    I can't find the AV function in the IR list because I need to have this in order to activate the DTV function but without switching the screen on.
    Maybe there's another way to do this...
  • 12-01-2008 2:55 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: AV DTV function
    Yes, there is. Create a button that sends the SAT command in audio (RADIO) mode.
    Stefan
  • 12-01-2008 3:16 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: AV DTV function
    .......and a radio, CD, etc command in TV mode too.
    Poor me, never win owt!
  • 12-01-2008 4:42 PM In reply to
    • Beogen
    • Belgium
    • Posts 135
    Re: AV DTV function
    OK, thanks, but in that case the primary function like radio or TV will be chosen and switched on before SAT will be activated. I used to do this with the BEO4 AV + DTV button without switching on any other device.
  • 12-02-2008 4:50 AM In reply to
    • stefan
    • Posts 1,733
    Re: AV DTV function
    Sorry, maybe I didn`t make it really clear. You don`t have to press RADIO and SAT. If you have the Beo5 Config. tool you create a button that looks like this: 0:000: RADIO: V-SAT. You can name this button for example. AV-DTV. This is the button that will activate DTV (SAT) in AV mode. It´s a one-button-solution.
    Good luck
    Stefan
  • 12-02-2008 4:40 PM In reply to
    • Beogen
    • Belgium
    • Posts 135
    Re: AV DTV function
    OK Stefan, thanks!
    This was the answer I was looking for
