Latest post 12-01-2008 3:22 PM by Roger. 8 replies.
Page 1 of 1 (9 items)
  • 11-30-2008 3:16 AM
    • beoko
    • Not Ranked
    • Joined on 05-10-2007
    • Posts 21
    Vista to Beomedia
    Hello,
    thist tread, I have been in the German forum set.
    Now I hope I am in the General forum can be helped.
    Unfortunately, my English is not so good but
    I have a problem with the wireless connection in my laptop to my Beomedia 1st Unfortunately, I can not connect to Beomedia when I click on "Own a Beomedia" gehe.Bei enter my password, I get the message "Beomedia1 could not be located. Beomedia Enter 1's IP ...... Sebst in Enter the IP address 192.168.1.101 I get no connection.
    The laptop's new! and except Vista with Service Pack 1, no other program except the current Beoplayerversion 4.83 installed. In addition, this laptop only the Windows firewall. This I had also been for a connection attempt off! Unfortunately without success. Nor was important to mention that a connection with my desktop PC via LAN cable on the router absolutely functioning properly, so an error in the password, an error in Beomedia and a mistake to exclude a connection, since the Beomedia to the router via Wi-Fi a connection to the WEB and N. Radio builds.
    The other, nor to mention a connection to Beomedia on my router via wireless, with my old, defective laptop functioned properly. This had a laptop running Windows XP.
    I hope you can help me with my laptop Winows Vista operating system XP SP1 with the Beomedia again to combine.
    I am already on despair. 've Also already in the firewall Beoplayer admitted. The ports 137-139 TCP and UDP 137-139
    I have been in the rules allowed. Everything until now without success.
    I would be glad if you can help me.
    Greetings!
    Andreas
  • 11-30-2008 10:28 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Vista to Beomedia
    Hi Andreas.
    As far as I know there are some certain issues with the Vista. However, in my opinion this should be a vista problem and not a Beomedia1.
    I never use vista since for hat ever you do you need to onfirm and create rule .......... Check the windows firewall and the connection settings in both machines.
    Sorry that I cannot help more.
     Regards
     Spiros
    Best regards
    Spiros
  • 11-30-2008 11:27 AM In reply to
    • beoko
    • Not Ranked
    • Posts 21
    Hi Spiros,
    Thank you for your reply. I hope one can say
    which regulate the vista my connection is blocked or how the firewall
    is set. I had also been turned off, unfortunately without
    successful.
    thanks
    Andreas
  • 12-01-2008 2:09 AM In reply to
    • beoko
    • Not Ranked
    • Posts 21
    Hello,
    nobody has an idea and can help me?
    Greeting
    Andreas
  • 12-01-2008 7:13 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    When you try to connect via your wireless laptop, please try to create some "traffic" on the BeoMedia 1:
    Start BeoMedia 1 via your tv. Select WEB and surf between various internet pages while your laptop tries to connect.
    Roger
  • 12-01-2008 10:03 AM In reply to
    • beoko
    • Not Ranked
    • Posts 21
    Hello Roger,
    Thanks for your answer. Unfortunately, your tip for me
    no success. Do you have Vista and the Beomedia 1?
    Best Regards
    Andreas
  • 12-01-2008 11:31 AM In reply to
    • Roger
    • Norway
    • Posts 870
    If your laptop can't see your BeoMedia 1 (do you have any software that can be used to detect computers currently connected to your network, like PC-cillin?), then the number one fault with Vista is this:
    "If Windows Vista is installed on the computer used in connection with BeoMedia 1, it is important that the time setting on BeoMedia 1 and the client PC are 'synchronised' (within 35 hrs.).
    Otherwise, BeoPlayer cannot connect to BeoMedia 1."
    Roger
  • 12-01-2008 12:49 PM In reply to
    • beoko
    • Not Ranked
    • Posts 21
    Hello Roger,
    Many, many thanks.Party!!!
     I'm very, very happy.Party!!!
    The true the error. The time of my Beomedia was completely adjusted.
    Thank you once again, you've responded to me, despite my poor
    English knowledge.
    Greetings!
    Andreas
  • 12-01-2008 3:22 PM In reply to
    • Roger
    • Norway
    • Posts 870
    Hi Andreas,
    The language shouldn't hold anyone back on the General Forum - thank you for posting on the General Forum, and by doing so more people will be able to search and find the answer to their challenges with their BeoMedia setup.
    Roger
