Latest post 04-18-2009 2:22 AM by Spiros. 12 replies.
Page 1 of 1 (13 items)
  • 11-28-2008 12:13 PM
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Wanted: a pb/rec head for Beocord 5500
    I got a non-working BC5500 with the problem of sound in only one channel. The head was open-circuit in the silent channel (checked with multimeter and swapping left/right channel).
    So if anyone has an extra head for this deck (it is told to be the same as used in 3500 / 4500 / Beocenter 9000 / 9500 / 8500) I'd like to buy one. Hopefully not too expensive, suggest a price. I'd like to have the head assembly as complete as possible as it's quite miniature if dis-assembled. (Head, fixing screws and frame and the wires to be soldered to the small board).
    I am located in FIN, I will pay the postages and I can pay with PayPal.
    Thanks in advance.
    Ville
    Bang & Olufsen - The art of controlling sound, picture and light
  • 11-30-2008 3:09 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Wanted: a pb/rec head for Beocord 5500
    Might be worth dropping Martin a PM.
    CraigSmile
  • 12-07-2008 1:25 PM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    I have already asked; unfortunately he doesn't have one. I am still searching; please note me if you have!
  • 12-08-2008 2:34 PM In reply to
    • h1npw
    • Top 75 Contributor
    • A cricket ball throw from Trent Bridge
    • Posts 776
    http://cgi.ebay.co.uk/Bang-Olufsen-Beocord-5000-Tape-Deck_W0QQitemZ170285030434QQcmdZViewItemQQptZUK_AudioVisualElectronics_HomeAudioHiFi_CompleteHifiSystems?hash=item170285030434&_trksid=p3286.c0.m14&_trkparms=72%3A1301|66%3A2|65%3A12|39%3A1|240%3A1318
     Hi
    This one is for sale on ebay and probably won't go for much money as it's pick up only and has a damaged front. If you were to win it I could pick it up for you and post the head assembly to Finland.
    Cheers
    Nigel
  • 12-09-2008 10:32 AM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    Hi!
    Thanks for your offer. It feels bad to part a complete deck to get this working; mine is not in too good external condition. I guess it would be a bit too complicated task and amount of work - I think I will just keep looking for the head itself. I don't want to have more "almost working" Beocords lying around... :) Or would you have any use for the rest of the deck?
  • 12-09-2008 11:46 AM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    The Beocord 5000 doesn't have autoreverse and uses a different tapehead compared to the 5500.
  • 12-09-2008 3:57 PM In reply to
    • h1npw
    • Posts 776
    Well spotted Martin......my senility is getting worse by the day Confused
    Cheers
    Nigel
  • 03-30-2009 5:35 AM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    I am still searching for this part.
  • 03-30-2009 5:40 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Hi there.
    I think I can help you. Pleaes PM.
    Best regards
    Spiros
    Best regards
    Spiros
  • 03-30-2009 5:53 AM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    PM sent.
    Yes -  thumbs up
  • 04-17-2009 9:35 AM In reply to
    Spiros,  can you help me also please, I need the red perspex front glass panel for a Beocord 5500, can you help, please let me know, thank you
  • 04-17-2009 10:06 AM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    Just to update: I have now a working BC5500, thanks to Spiros who supplied parts from his decks. Yes -  thumbs up
  • 04-18-2009 2:22 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    hi Peter,
    I 've sent you an email. Please check.
    Ville you are more than welcome. I'm really happy the Beocord was brought back to life!!!!!!!!
    Best regards
    Spiros
