Latest post 12-09-2008 8:34 PM by flex73. 8 replies.
Page 1 of 1 (9 items)
  • 11-28-2008 11:56 AM
    Beocenter 9000
    Hello! I'm looking for a Beocenter 9000 in pristine condition
    with box and manuals! Hope to find one!
    Many thanks,
    Alkis
  • 11-28-2008 12:08 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Beocenter 9000
    i have both a 9300 and also a 8500 both unblemished(i think) pm me if interested
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 11-28-2008 12:09 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Re: Beocenter 9000
    forgot to add the 9300 is complete with box and manuals - it is however currently in france!
    tony
  • 12-04-2008 9:35 AM In reply to
    Re: Beocenter 9000
    Thank you very much for your message but I'm looking
    for a Beocenter 9000 only...
    Best regards,
    Alkis
  • 12-04-2008 11:45 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Beocenter 9000
    Alki kalimera.
    Ligo diskolo gia 9000. Giati mono afto to sigkekrimeno?
     Filika
    Spiros
    Best regards
    Spiros
  • 12-05-2008 12:25 AM In reply to
    Re: Beocenter 9000
    Hi, i am based in Singapore. I have a beocenter 9000 with upgraded CD mechanism(with clamp) changed by B&O Singapore. The set was sent in for the change last year and checked. The trim is in bronze and i believe the new CDM will last you many years to come. You may find a set with old CDM but you have to be careful as it might breakdown half way through.
    My old original box was thrown away due to the humidity problem but i have the after-sale box from them which i got it for my BC9500. I am not able to find the manual unfortunately. Let me know if you are keen and make me an offer.
  • 12-05-2008 12:27 AM In reply to
    Re: Beocenter 9000
    Hi, i am based in Singapore. I have a beocenter 9000 with upgraded CD mechanism(with clamp) changed by B&O Singapore. The set was sent in for the change last year and checked. The trim is in bronze and i believe the new CDM will last you many years to come. My old original box was thrown away due to the humidity problem but i have the after-sale box from them which i got it for my BC9500. I am not able to find the manual unfortunately. Let me know if you are keen and make me an offer.
  • 12-09-2008 1:34 PM In reply to
    • js
    • Top 500 Contributor
    • Joined on 09-07-2007
    • Brussels
    • Posts 208
    • Silver Member
    Re: Beocenter 9000
    flex73:
    I have a beocenter 9000 with upgraded CD mechanism (with clamp)
    Hi flex73,
    I also have a Beocenter 9000 and I wouldlike to upgrade the CD mechanism. Could you please let me know more about your upgrade with clamp? Thanks a lot for that.
    Kind regards,
    Jean-Sebastien
  • 12-09-2008 8:34 PM In reply to
    Re: Beocenter 9000
    Hi js,
    Sad to say or i believe that the CD clamp mech. type replacement for the beocenter 9000 is no longer available with the service center,  i do not know if they still have it at your area, doubt so :( .I was lucky to get the replacement done, believed to be one of the very last still in stock at my svc center.:). Even the newer BC9500 parts are obsolete now. Basically, the new mech requires you to clamp the disc before you play as opposed to the old fragile clip type which originally came with the 9000.
    flex73
