Latest post 11-26-2008 2:02 PM by PhilLondon. 6 replies.
Page 1 of 1 (7 items)
  • 11-26-2008 11:07 AM
    BeoPort with Airport Express
    Is it possible to connect a Beoport to a apple computer wireless? Apple has the Airport Express with a Usb connection and an audio connection. So you think it's possible to connect a Apple macbook wireless with a Beoport. Does anybody know if it works.
  • 11-26-2008 11:09 AM In reply to
    Re: BeoPort with Airport Express
    You would still need to connect the USB...
    P.
  • 11-26-2008 11:19 AM In reply to
    Yes i know but the airport has a usb connection but i'm not sure if this is a normal usb or only a printer server usb
  • 11-26-2008 11:23 AM In reply to
    i believe that you are correct: just a print server... hackable?
    • B&o bottle opener
  • 11-26-2008 11:29 AM In reply to
    You can only connect a printer or IR receiver from Keyspan
    http://store.apple.com/us/product/TB638LL/A?mco=MTIxODk3Mw
  • 11-26-2008 11:42 AM In reply to
    whoa! wait a minute... that sounds like that port is much more than a print server then!
    i need to get my head around this one! ...or is the keyspan simply tricking the port??? -meaning this port is hackable and seemingly simply so?
    • B&o bottle opener
  • 11-26-2008 2:02 PM In reply to
    Apple has built in a special driver for the Keyspan remore and the function is also built into itunes.
    I check on the net, and Apple really recommand to only connect 1 and only one printer, 1 and only one remote sensor, or both using a USB hub.
    Other brands are selling wireless USB hubs. They use Wifi and USB. If drivers are available for the mac, I would get one of this, connect the Beoport on one USB port, a USB soundcard on another one.
    http://www.gadgetell.com/tech/comment/belkins-next-gen-wi-fi-usb-hub/
    http://www.griffintechnology.com/products/imic
    p.
