Latest post 05-24-2007 1:33 AM by Doman. 4 replies.
Page 1 of 1 (5 items)
  • 05-18-2007 4:26 PM
    • Doman
    • Not Ranked
    • Joined on 05-18-2007
    • Sweden
    • Posts 10
    How to polish a pair of bl8000?
    Hi there!
    It´s time to polish my pair of bl8000. I got some small marks at them, nothing deep, but quite noticable. How do I easiest get rid of them and get that sparkling finish at the same time? I read some threads in a garage-forum where they used rotary hammers and stuff, maybe a bit overkill for my precious. Autosol maybe?
    Best regards
    /Doman
    Proud owner of bs9000, bc6000, bl8000, bl4, DeToma X501
  • 05-18-2007 4:51 PM In reply to
    Re: How to polish a pair of bl8000?
    I would leave well alone and stop looking at the back of them!!
    The problem with polishing is that you will destroy the anodised finish over a large area and it will never match the rest of the cabinet. So, instead of a small mark you will end up with a big one.
    Regards Graham
  • 05-18-2007 5:59 PM In reply to
    • Tom
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    I would not touch my BL8000 with anything than a dry cloth. No chemicals, you "do them more bad than good". Leave them as they are and listen to them instead of watching at them (although they really a beautiful)
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 05-18-2007 7:53 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Agreed. You are wasting your time trying to polish them, they will look awful if you try with any kind of abrasive or strong solvent.
    If you have a really bad mark on them, i'd suggest re-casing by your local B&O engineer/dealer. Otherwise - leave well alone.
    Sorry if this isn't what you want to hear, but theres nothing worse than having the best intentions and ruining your B&O.  On his first day, Matt (LifeStyle AV) cleaned a mark off the front of a Beolab 2000 with thinners!!  Of course, it melted the grey plastic, but thankfully i laughed and counted it as a valuable lesson in being very careful with B&O.
    He has since gone on to be a star employee by the way. Laughing
    Lee
  • 05-24-2007 1:33 AM In reply to
    • Doman
    • Not Ranked
    • Sweden
    • Posts 10
    Ok, thanks for your advices! Fortunatelly there is no big issues. Good that I asked somebody before I started to experiment :)
