Latest post 05-18-2007 4:22 PM by joeyboygolf. 5 replies.
Page 1 of 1 (6 items)
  • 05-18-2007 2:07 PM
    MC / MCL question
    Hi all, I know Kevin was linking rooms via some older posts... Thanks to everyone for the help so far.
     My situation is, i'm connecting a BS9000 with a masterlink cable to a Beolink converter, then on to the AV7000 (surround processor), from there on to the 4 active speakers via Powerlink.
    Question is, if I wanted to do link other rooms. How do i do that, ???  From the AV7000? or from the Converter before the AV7000.
     I'd like to add some beolab 5000 active speakers in 2 or 3 other rooms in the house and have as much control over them as possible.
     Thanks in advance for any help. Keith
  • 05-18-2007 2:18 PM In reply to
    Re: MC / MCL question
    If you are linking rooms, I would use ML from the BS9000 as that is the more modern system. Especially if you are going to use active speakers.
  • 05-18-2007 3:13 PM In reply to
    Okay, so Peter, the 1 masterlink off the bs9000 is going to the converter, then i think it's datalink to the AV7000....
     So that Masterlink off the 9000, can it be split?? if so how?? then off to the hockey puck eyes??? yes??  Thanks Peter a ton..
  • 05-18-2007 3:27 PM In reply to
    Nearly! It goes to a control box called a Beolink Active to which the hockey puck attaches.The speakers attach to the control box. The ML wire can indeed be split.
    Best of luck.
  • 05-18-2007 3:52 PM In reply to
    Great Peter...so is the ML splitter a simple cable from BO? Then one end into the AV7000 and the other to the BO active?? Thanks,
  • 05-18-2007 4:22 PM In reply to
    You need to buy a ML junction box Not expensive. <£10
    Regards Graham
