Latest post 11-24-2008 11:28 AM by stotty1111. 7 replies.
Page 1 of 1 (8 items)
  • 11-24-2008 7:40 AM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Connecting BS Overture to BL 6000
    Hi allConfused
    As an active (speaker) virgin so to speak do i just need 2x powerlink(8pin) cables to get the system working ie bs -> bl(1) -> bl(2)
    Apologies for what is likely a very simple question but having looked at the manuals, beoworld based, i am still a mite confused
    thanks in advance
    t
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 11-24-2008 7:43 AM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: Connecting BS Overture to BL 6000
    2 PowerLink Cables, and 3 Mains cords.  That will do it!
    Congrats on the system.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 11-24-2008 7:47 AM In reply to
    You can connect both cables from the beosound to the speakers, or you can have one cable to a speaker and then another cable from one speaker to the other.
    You will need electricity cables going to each speaker. They come from any socket near the speakers, not necessarily from the hi-fi itself.
  • 11-24-2008 7:54 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    EmbarrassedThanks for quick responses - having just looked at good old ebay mk1 mk2 or mk3 cables - or will any mk do?
    salut
    t
  • 11-24-2008 8:37 AM In reply to
    MKIII is thinner as it does not transport the display information.
    MKII is the thick cable and is more expensive. It is necessary when you have speakers with display (Penta, Beolab 4500) or speakers with ICEPower amplifiers.
    If you are going to do some building work to hide them, or if you plan to upgrade later to newer speakers get the MKII otherwise the MKIII is enough.
    p.
  • 11-24-2008 8:39 AM In reply to
    Hi t,
    Any version of Powerlink cable will work with Beolab 6000 (it is basically the model of speaker which dictates the version you need).  I have written a guide to the various types of Powerlink here.  If you are considering installation of the cables in the walls, floor or ceiling of your home, I would always recommend mark 2 "fully wired" cables, as these will work with any other Beolab speakers you may decide to buy in the future.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 11-24-2008 8:44 AM In reply to
    Hi Phil,
    Sorry to be picky, but mark 3 cable is fine for all ICE Power (Digital) Beolab speakers except Beolab 5.  I agree with everything else you said! Yes -  thumbs up
    Best regards,
    Steve.
  • 11-24-2008 11:28 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Thanks guys!
     Yes -  thumbs up The fog begins to clear - now back to ebay for the cables!
    salut
    tony
