Latest post 10-22-2009 10:58 AM by alfio. 5 replies.
Page 1 of 1 (6 items)
  • 05-18-2007 12:19 PM
    • frog
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Posts 191
    PUC and Dreambox
    Anyone know if the PUC on a Beosystem 3 will control a Dreambox? I can't find the STB-C list anywhere on the manual pages (must be me...)
    Regards
    frog
  • 05-18-2007 2:03 PM In reply to
    Re: PUC and Dreambox
    Forgive my ignorance - what is a Dreambox?
  • 05-18-2007 3:07 PM In reply to
    • frog
    • Posts 191
    Big Smile [:D] Re: PUC and Dreambox
    Forgiven....
    It is a satellite receiver brand. I have the 7025 but the models all use the same type of remote control
  • 05-18-2007 3:22 PM In reply to
    Deambox 7000 is listed - try code 48
  • 05-19-2007 8:35 PM In reply to
    • frog
    • Posts 191
    Great - Thanks.
  • 10-22-2009 10:58 AM In reply to
    • alfio
    • Not Ranked
    • Joined on 10-22-2009
    • Posts 2
    Hi
    I used the PUC ina BV-8-40 with a dreambox 5620. All functiosn works with the exception of ESC key (I used exit but no effect) and the TV key that is interpreted as MUTE.
    Any suggestions ?
