Latest post 11-21-2008 8:00 AM by h1npw. 3 replies.
Page 1 of 1 (4 items)
  • 11-21-2008 7:30 AM
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Urgent please - will a USA Beocom 4 work in the UK?
    Smile
  • 11-21-2008 7:35 AM In reply to
    Re: Urgent please - will a USA Beocom 4 work in the UK?
    Short answer is no. There may be a way of getting around this though. Keith is your man.
  • 11-21-2008 7:56 AM In reply to
    ? why do we think no?
    the frequency is different and not approved for use in the UK as its the wrong band ... but as long as it matches the base unit ... it will communicate ... i would have thought that the only issue is the wired connection to the system and I believe that to be ok.
    Neil
  • 11-21-2008 8:00 AM In reply to
    • h1npw
    • Posts 776
    Thanks for your quick response guys - panic now over......
    This
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=160298675410
    was sitting at $10 with 10 minutes to go....
    I didn't bid quite enough Sad
    Cheers
    Nigel
