Latest post 04-21-2009 2:41 AM by elephant. 29 replies.
Page 1 of 2 (30 items) 1 2 Next >
  • 11-20-2008 4:28 PM
    Beo5 3rd Party XML Generator Version 1.0 is now available
                             ANNOUNCEMENT
    Jacob (Weebyx) and myself are very pleased to announce the completion of the Beo5 3rd Party XML Generator which has been made available to Silver and Gold members for download.
    This is a Windows based Tool (sorry Mac users) which allows the automatic generation of XML files for ANY 3rd party Infra-red remote controlled products which are subsequently used by the B&O Beo5 Configuration Tool to configure and download to your Beo5. The tool has been tested with 52 different 3rd party remote controls and successfully produced a fully working Beo5 for each 3rd party product.
    All members can read the Windows only HELP file by downloading it HERE to fully understand how to use the tool.
    The Beo5 3rd Party XML Generator is found under the "Service Manual" section of the Beo5 HERE for Silver and Gold members.
    As a service to members you will also find HERE the ability to upload completed XML files for use by other members. So I would ask anyone who produces an XML file with this tool, once tested to please upload it to the server.
    If you have any problems with the tool we would ask you to post to the Beo5 forum.
    Regards Keith....
  • 11-21-2008 2:34 AM In reply to
    Re: Beo5 3rd Party XML Generator Version 1.0 is now available
  • 11-21-2008 2:39 AM In reply to
    • hebo
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Sweden
    • Posts 305
    Now it´s time to blow the dust away from my Beo5 and start using it.
     Thanx Keith & Jacob
     BV10
  • 11-21-2008 2:55 AM In reply to
    Will give it a go...
  • 11-21-2008 3:18 AM In reply to
    When downloading the HELP file (CHH format) which is in a ZIP file, save the zip file to your computer and extract the help file and then run it. If you try and double click on the help file within the zip file you will get page not found.
    CHH format means "Compiled HTML Help file" which until recently was Microsoft's standard helpfile format.
    Regards Keith....
  • 11-21-2008 4:07 AM In reply to
    This really sounds like something.
     What about putting the manual out for public download, I'm sure that a great and working piece of sofware, can generate Silver / Gold members.
    ....I am considering this excact thing myselves now ;-)
     Does it enable me to control something like my Mac, my Mediacenter PC and my Xbox directly without the need for the PUC in the TV?
  • 11-21-2008 4:08 AM In reply to
    Macsat,
    In answer to your last line, the simple answer is YES
    The HELP file is available for public download, its ONLY the software itself which requires you to be a silver or gold member.
    Regards Keith....
  • 11-21-2008 4:39 AM In reply to
    Sounds very great....and very much sounds like you got yourselves one more paying member on BeoWorld ;-)
     I will definally give it a go this weekend, as my Beo5 is standing on a shelf looking quite nice, but not beeing used at the moment.
     This would mean that I can see the use for it again though :-)
  • 11-21-2008 6:09 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Thank you Keith,
    Great work!!
    Regards
    Quim
  • 11-21-2008 8:43 AM In reply to
    Keith,
    What are the configuration software version and Beo5 firmware version requirements for this?
  • 11-21-2008 11:06 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    My word, we have some clever folk as members of Beoworld ....(I take it that jandyt wasn't involved)Laughing
    Well done chapsYes -  thumbs up
  • 11-21-2008 11:29 AM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    I have created my first xml file (little one)... and it works!!
    I can turn On and Off my Tvix 6500 without IR transmitter.
    Thanks again, Keith!!
    Quim
  • 11-21-2008 12:30 PM In reply to
    • Weebyx
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Quim43:
    What about me :(
    Great you tried it and it works :) Let us hear about you experiences and any new ideas/features/bugfixes you would like to see implemented in the future.
    /Weebyx
  • 11-21-2008 12:31 PM In reply to
    • Quim43
    • Posts 1,030
    • Gold Member
    You are right, sorry
    Thank you very much Weebyx Smile
    Quim
  • 11-23-2008 12:03 PM In reply to
    • TWG
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Keith & Jacob (Weebyx), I want a child from you Big Smile
  • 11-23-2008 1:15 PM In reply to
    • cone
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Oviedo/SPAIN
    • Posts 598
    I have a Philips Pronto remote control, I would like to know how to convert .ccf files in HEX files.Thanks
  • 11-24-2008 4:02 AM In reply to
    There is no easy way of doing this without writing your own programme, but one available solution is DecodeCCF which you can download from HERE and is written in C++ and runs in command mode only.
    The best way is to convert each Pronto code using the Lintronic software, you don't need the converter box
    Regards Keith....
  • 11-24-2008 6:00 AM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    This really is good news, and I'm sorry it has took me so long to comment on it.
    Am I right in thinking that this now facilitates the use of Beo 5 to control B&O equipment that is not Beolink 1000 compatible?
    The late 80s Beomaster 5000 (MCP) and the Beomaster 3000 (Terminal 3000) spring to mind; or even the earlier beautiful Beomaster 8000.
    Poor me, never win owt!
  • 11-24-2008 9:00 AM In reply to
    I've created a xml template for Sony trinitron TV sets using this new "Beo5 3rd party xml generator" and works great!
    It will be ready to download in this web site very soon.
    Thank you both for the stunning work, and special thanks to Keith for testing and all your precious help.
    Now my Sony TV set is fully controlled by Beo5 LOT better than using the original Sony remote!!! due to the beo5 range power, and the higher precision of the keys.
    Best regards
    Santiago
  • 11-25-2008 6:51 PM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Honestly, that's the best news I've ever heard concerning the Beo5 : that could maybe make me buy one... Shame on B&O for not having released this software, and thank you Keith & Jacob! B&O must pay you : I'm sure more people will buy a Beo5 now...
  • 11-25-2008 7:00 PM In reply to
    mbee:
    agreed! this makes all the difference in the world! i may have to scratch a few things from the xmas list and put on a beo5!
    GREAT WORK GUYS!
    • B&o bottle opener
  • 11-26-2008 6:45 AM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    mbee:
    Just remember to get the Config Software from your dealer when you buy one, this i guess will be the hard part, but make it a condition to have it, or you won't buy the Beo5.
    In these times, the dealers should be happy if they could sell a lot of Beo5's :)
    /Weebyx
  • 11-29-2008 11:04 AM In reply to
    • Spiros
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    If anybody had the xcruiser Sat rx would really help!!!
    Congratulations to both of you. This is an excellent job
    Best regards
    Spiros
  • 11-30-2008 12:29 PM In reply to
    • beoandy
    • Top 500 Contributor
    • Vienna
    • Posts 84
    • Gold Member
    Hi!
    Why are the3rd party codes only useable with Beo5 soft keys? Beo5 software 1.34. ConfigurationVersion is 1.30.
    beoandy
    BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, Avant 28, BS 4500, BC 9500, etc....
  • 11-30-2008 2:23 PM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    beoandy:
    Hi!
    beoandy
    I have no problems using the hardkeys. Just select properties and 3PartyIR tab, and select the action you would like. One thing though, it seems that the action HAS to be available as a softkey for the tab page to include the action to be used for the hardkey.
    /Weebyx
