1st March February 2012
Latest post 11-26-2008 3:58 PM by Zugn. 8 replies.
11-20-2008 2:25 PM
Zugn
- Joined on 03-01-2008
- Posts 20
Beolink 7000 Repair (...a lot!), need a bit help!
Hello! I know, it isn't easy, but i decided to buy a problematic BL7000, and try to repair it! I make some progress, now the LCD is working, and no pixel errors so far!:) The background lighting is still k.o. I measure the voltage between the brown and black wire, but it was 0V. Measure it also on the bottom circuit to ensure there is no defect wire, but it was also zero Volts. How can i repair this problem? Also it can happen, that the capacitor somewhere close to the IR diodes are also faulty. I read somewhere, that this can stop the two way communication. Wich ones should be replaced? I can't see the volume value in the red LED dot matrix display. Also not the clock. I try to set it, but no success. This group of display should work, sometimes i have two horizontal stripes instead of the volume value. That's all, i think.:) Thanks in advance for any help!:) Charles
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Re: Beolink 7000 Repair (...a lot!), need a bit help!
You got a bit of work there buddy  I had my Blink 7000 recently serviced due to two-way com was broken. Five capacitors was changed on the top end of the remote. I found a picture, with the capacitors high-lighted here on this website, try a search, and you'll find it for sure. Best of luck!  It warms my heart knowing that there's many of us trying to keep these Monoliths alive.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Zugn
- Posts 20
Thanks!;) I think, the Beolink 7000 is still the best remote controll on this planet, so this one must work, for sure!:) I read somewhere about two capacitors, but see also a lot more, so this sounds me more logical to change all these! Thanks!:)
Zugn
- Posts 20
New problem: I charged fully the remote, but it works only 1 seconds, then it give up.:( If the remote is working, it try to lift up the display, but this works also 1 s long, so just a few mm's, and then dead. It don't happen before, the BL7000 was chargeable on a regular basis. One full charge was enough for a normal time period of operation, so don't think so, that the batteries are k.o. It is a common fault, or something special? Thanks: Charles
bayerische
- Helsinki, Finland
- Posts 3,593
How long since it worked flawlessly with the battery? I believe leaving the battery empty for a long time will kill it.
-Andreas
ridax
- Joined on 04-16-2007
- Posts 44
Maybe the charging doesn't work in the remote?
Zugn
- Posts 20
bayerische:How long since it worked flawlessly with the battery? I believe leaving the battery empty for a long time will kill it.
The remote itself wasn't often used, but when i try to use it, it works! After discharging and charging, the remote works regular. And now this. The remote works 1 day before werry well, just now, something is wrong... It happen after a new fully charging.
Zugn
- Posts 20
ridax: Maybe the charging doesn't work in the remote?
It works every time, but now, something is defect from one minute to the other... The red dot lights during charging...
Zugn
- Posts 20
I decided to charge it again, maybe... Again 1 full night on the charger, the red dot lights again during the charging, and today, everything working like before! Ok., this mistake is solved now.:) But all the other problems still here. Anyone has some ideas, how to solve these? Thanks: Charles
Page 1 of 1 (9 items)
