I got my new BS2 just today. It has the 1.x.x.'something' firmware which seems to be very old and causing a lot troubles. I am too running on MacBook. Is the firmware really the same thing as mentioned in here: ?
http://www.bang-olufsen.com/page.asp?id=145
If it is then the 1.1.0.12 I have is really old and should be updated at once. It took me lot of time to figure out that this was (or now seems to be) the trouble. As the newest installation package on the B&O website gives this version I thought it to be the newest...
One thing that took me ages was that when you format the card on a reader with PC you have to choose the format to be FAT (not FAT32 or anything else). Mac won't let you format in FAT, the oldest is FAT32.
My problem is that I can get the BS show up in iTunes and copy music in. If I try to make a playlist it creates one with the default name of "untitled playlist". It can't be renamed (it won't change) nor deleted (iTunes crashes). If I name the folder in Finder it won't be shown in iTunes.
I can't update the firmware as I don't have a PC running XP (Vista definetively doesn't work with this and my old Win98 laptop gave some weird error when tried) at home. When I next time go to work (now on holliday) on thursday I can get it done.
When the BS is on the charger you can switch between GREEN (playback) and RED (computer connection) by pressing the GO button for two seconds. The timing seems to be quite critical - it might need few try to get it right. Flashing RED means that it's connected and charging battery (stable RED will come when charged).
The key-combinations are hardly logical, if you wan't to lock the keys would you first thought to press both << and >>?
Also to mention formatting in the daily functions is a bit surprising!
Bang & Olufsen - The art of controlling sound, picture and light
