Latest post 11-19-2008 2:06 PM by Russ. 6 replies.
Page 1 of 1 (7 items)
  • 11-19-2008 8:49 AM
    BeoLab 5 and BeoVision 7-40 Connections
    I should know this, but here we go, could i ask how people connect the BeoLab 5 speakers (dont have) with a BV7_40 that i do have?
    Definately the powerlink, but is there a digital out for the bv7-40? Do people connect the BL5 to a BS9000 instead and route the TV sound to that?
  • 11-19-2008 9:02 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: BeoLab 5 and BeoVision 7-40 Connections
    BV7-40 - Powerlink - BL5
    BS9000 - Masterlink - BV7- 40
    BS9000 - spdif - BL5
    BS9000 in A.OPT 0. BV7-40 in V-OPT 2. BL5 in L-OPT 0
    BL5 chooses the digital input, when a digital signal is detected. Volume control works via Powerlink / BV7-40
    Stefan
  • 11-19-2008 9:14 AM In reply to
    Thanks Stefan,
    I see. Is there a big difference between the sound quality of just powerlink and digital?
  • 11-19-2008 9:23 AM In reply to
    • stefan
    • Posts 1,733
    No big difference. But I can hear it. You can test that when listening to CD disconnect the spdif and you will hear the analog signal.
    I think in this configuration the big difference is the BL5 !
    Stefan
  • 11-19-2008 9:25 AM In reply to
    Encouraging last words :) saving up I am :)
  • 11-19-2008 12:57 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    If you want to get the most out of your BeoLab 5s, it may be worth investing in a BeoCenter 2, BeoSound 9000 or 5 which all have digital outputs in order to drive your BeoLab 5s to their maximum ability. Not necessary if you want to get a stunning sound though...
     Weekly top artists:
  • 11-19-2008 2:06 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Obvious, when purchased new, but easily overlooked when purchased second-life.  You MUST ALWAYS use fully wired PL cables with the BeoLab 5's.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
