Latest post 11-17-2008 7:58 AM by saf. 5 replies.
Page 1 of 1 (6 items)
  • 11-17-2008 4:27 AM
    Beosound 9000
    Hi
    I have a beosound 9000 and it makes a strange noise when each cd spins.  It sounds like the cd is scratching on something but when I take the cd out there's no marks on it.
    Any ideas?
    Thanks.
  • 11-17-2008 5:06 AM In reply to
    Re: Beosound 9000
  • 11-17-2008 5:07 AM In reply to
    Re: Beosound 9000
    I think it´s the taco sensor or some like that
    I had the same problem
    No big cost to change/adjust
  • 11-17-2008 6:12 AM In reply to
    Re: Beosound 9000
    hi,
    have you recently changed the beosound 9000 mounting position horizontal/vertical/flat?
    if so it could be simply adjusting the cd clamper configuration at the back of the unit to the right position
    jason
    jason
  • 11-17-2008 6:18 AM In reply to
    Re: Beosound 9000
    I have the same problems sometime and when I clean the lens it is OK, but don't clean the lens with wet things only dry cotton.
  • 11-17-2008 7:58 AM In reply to
    • saf
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 458
    Re: Beosound 9000
    If what Jason says doesn't help then it is the black plastic clamper arm which is slightly bent and touches the spinning CD and you hear a scraping sound. It needs replacement (p/n 2854003),  possibly, though less likely, only an adjustment.
    Not a big deal at all, but best to get both done by your dealer ...
