Latest post 11-16-2008 1:16 PM by macjedimatt. 2 replies.
Page 1 of 1 (3 items)
  • 11-15-2008 1:54 PM
    Loose wire on Beogram 8000
    I've just acquired a Beogram 8000 that has been sitting for several years. It seems to work pretty good aside from not having a cartridge. Upon my internal inspection I noticed some of the wiring had what looks like rat chewing damage (it was mostly taken apart already). I have been able to repair most of it but there is one wire that I can not seem to figure out where it goes. It is the blurry black wire on the left. It appears to be coaxial like the audio wires that go to the output jack. Any ideas?
    high res image: http://oz.plymouth.edu/~mpbedard/Beo8000wire.jpg
    beo8000wire
  • 11-16-2008 6:46 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Loose wire on Beogram 8000
    Welcome to Beoworld !   Yes -  thumbs up
    It's a shielded lead. The outer shielding is connected to ground inside the CPU casing so should just be left isolated at the free end.
    The center wire connects to the one-pin connector sitting at the extreme lower left board corner in your photo.
  • 11-16-2008 1:16 PM In reply to
    That is what I suspected but wasn't sure. Thanks for your help!
