The light on the slave arm went out. I am referring to the one that shines from the arm above the record to the record.
I believe that the light is a 6v 25a micro bulb (#8230055, pg9-11 in the B&O manual). I have not been able to locate a seller of this micro-bulb. I did find a mini-bulb and I put it in. The mini-bulb, however, is too big and it is not centered correctly. So, the light shines at an angle. The arm sensor does not notice the reflection from the record. The mini-bulb is a tight fit as it is and there is no way to move the mini-bulb to get its light centered. So, I think I need the mico-bulb (6v 25a micro-bulb). If you know of a seller for this micro-bulb will you please let me know?
There may be an alternative working solution. I did find a 6W MICRO LAMP 70MA . This bulb pulls a bit more power. Would this bulb work? Would the extra draw put extra wear on other components in the TT? Or, is there some other solution that I have not considered?
I would really appreciate any advice you might have.
Thanks for taking the time to read my post.
Kirk
