Latest post 11-15-2008 7:29 AM by stefan. 1 replies.
Page 1 of 1 (2 items)
  • 11-15-2008 12:46 AM
    Linkroom control?
    Hi all
    Anyone know how you are supposed to control all BS5 from a linkroom with just a Beo4?. Does a menu appear on your linkroom tv showing content. BM5 should be able, like Beomedia, to show pictures and web on your linkroom tv´s so i suppose a control functionality is also available. Otherwise, what about twoway communication with Beo5.
    If either of these solutions are not available, i am sorry to say "Another not quite sought through solution from B&O"
    Lets wait and see.
    Regards
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 11-15-2008 7:29 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Linkroom control?
    You will be able to control BM5 from video linkrooms as you do with BM1. Pressing L-PC will activate BM5 on you (compatible) link-TV.
    You can also create "coloured lists", which will be activated by pressing coloured buttons. You can also add/remove tracks from these lists and step for-/backwards.
    The demo devices, that will be delivered to the dealers end og november, will still be "stand alone" versions not being connected to a Beovision.
    Sorry, 2 way communication with Beo5 will not be possible, as I was told...(?).
    Stefan
