Latest post 11-14-2008 10:30 AM by PhilLondon. 9 replies.
Page 1 of 1 (10 items)
  • 11-14-2008 5:09 AM
    BS5 purchase options.
    Something I picked up on in another thread, there seems to be an option as to how you can buy BS5.
    Anyone know what these are and cost?
  • 11-14-2008 8:31 AM In reply to
    Re: BS5 purchase options.
    You can pre-order one now with your dealer to receive one of the first allocations when it is officially released in the Spring next year (apparently March/April, but expect the usual long delays!)
    Your local B&O will decide how much of a deposit you pay. I've heard the cost will be about £3,500 for both the master and head unit, but don't know if that's with remote or not - very probably not. I've also heard that you will have to pay to have your CDs ripped onto it at about £1 per disc, but since no-one will get one until next year anyway, this might be wrong/change. It's unlike B&O to give anyone anything for free though!
  • 11-14-2008 9:22 AM In reply to
    I know that if you order it within the month in Bang & Olufsen shops in denmark within the month, seven years of total warranty is thrown in the hat.
    The deposit is typically 10-20 % of total price..
    The option you are maybe mentioning is that you can purchase the BeoSound 5 WITH or WITHOUT the BeoMaster 5..
    BeoVision10-46MKII,BL3,BL2,BS8,Beo5
  • 11-14-2008 9:29 AM In reply to
    Beosound 5 does not work on its own, so I doubt it can be ordered without the Beomaster 5.
  • 11-14-2008 9:51 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    From what i have heard it is the BeoMaster 5 that can be ordered separately in the near future.
    (control via Beo4/Beo5 + infrared-sensor)
  • 11-14-2008 9:57 AM In reply to
    Ignace:
    This brings a question to me: I doubt that it is controlled by a separate IR sensor if you have a Beo TV, otherwise you could not control it from a link room. However, as it does not have a Scart, it won't have AVL, so I am wondering how it works...
    p.
  • 11-14-2008 10:19 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    The BM5 does have a socket for an external IR-sensor, so i wonder what that may be used for.
    Smile
  • 11-14-2008 10:23 AM In reply to
    If used without a B&O television, like some B&O Video recorder used to have an external IR socket.
  • 11-14-2008 10:28 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Right,
    how will a Beovision send (or relay ir) commands to the BM5, i guess via Masterlink ?
  • 11-14-2008 10:30 AM In reply to
    How does it control the Beomedia 1 when you press the PC Key? Through the Scart or through the ML?
