Check if it has lost the puc settings by pressing:
Menu > Options > Connections>
Then select the port that the STB is connected to which will either be
DTV (STB)
V. AUX (STB)
Click on it, select the type of Sky box from the list. Select "Follow TV" or "Never" on the next menu then click go to save. This should sort the problem out!
