Latest post 11-13-2008 1:59 PM by richtoy. 1 replies.
Page 1 of 1 (2 items)
  • 11-12-2008 4:16 PM
    Beomaster 3000-2 Advice please
    I was recently very fortunate in acquiring a Beomaster3000-2.  It has been trapped in aloft for the past 17 years and was covered in dirt.
    This is the process I went through and the outcomes:
    1.  When Iplugged it in there was no sign of life at all.    I removedthe wooden cover and peered into the back and was so pleased to find theoriginal wiring diagram in perfect “as new” condition fastened to the back ofthe wooden cover and in a brown envelope. I had a good look around inside and found that the connection to thestereo light area had been disconnected. Once this was plugged back in and was connected back to the mains itcame immediately into life, although the green stereo light does not and hasnot yet come on.
    2. I plugged in some speakers and there was nothing but aloud constant humming no matter what I did.  Next step check on Beoworld, Vintage products.  I entered a search for the Beomaster3000-2 and up came a series of threads which I read through and the first thingI notice was that this was a common problem but easily solved, Fantastic!  So I followed the threads and theadvice given.  I sprayed all thecontacts I could see including the test switch at the rear.  I also removed the aluminium strip onthe front with the sliding controls on and then cleaned the switches behindwith a very fine emery board on the metal strips inside. I also gave these athorough spray with contact cleaner and then silicon lubricant.  I reassembled it and tried again.  Even louder buzzing, on no!  I then remembered something buried deepin one of the Beoworld threads that mentioned a problem with the testbutton.  I switched this to thedown position and the buzzing stopped. I tried both the radio and my iPod plugged into the tape sockets on therear and I could hear music but very very quietly.
    3. I took the top and front panel off again and gave anotherapplication of contact cleaner. Reconnected and the same result but this time when I switch the testbutton to the up position the sound is much much louder but there is still aconstant buzzing in the background. Also having adjusted the balance slider I notice that with both theradio and the iPod that there is nothing coming from the left speaker only theright.  If I slide the balanceselector all the way to the left I get no sound at all but all the way to theright, some sound as described above.
    So, finally, can anyone please give me any advice on what mynext step should be? Should I keep cleaning the contacts with spray?  I have also noticed that on the bottomthat there are some adjustable screws with L & R on for different inputs oroutputs.  As I have no user manualI have no idea what these are for. Also it has become obvious to me that someone has previously tried tocarry out some repairs on this Amp and I wonder if they may have altered thesetting on the L&R screws on the bottom, what do these do, should I tryadjusting them?
    The very last thing is good news; I have spent a good fewhours now with very fine wire wool and bees wax and the wooden cover looksgreat.  I have also been cleaningall the aluminium with cotton buds and it has all come up looking likenew.  Externally it looks like ithas just come out of the showroom I just wish I could make it work perfectlyagain as this is such a beautiful looking piece of furniture in its own right.
    Any help or advice that you can offer would be greatlyappreciated and hopefully will result in a Beomaster 3000-2 being restored backto its original beauty.
    Many thanks
    Peter G
  • 11-13-2008 1:59 PM In reply to
    • richtoy
    • Top 500 Contributor
    • Joined on 09-20-2007
    • Valkenburg, Netherlands
    • Posts 184
    • Gold Member
    Re: Beomaster 3000-2 Advice please
    Hi
    I have renovated 4 of these, a BM4000 and a BM4400 and they all needed capacitor kits that you can get with a very nice diagram from user dillen.  I would also recommend changing the two large capacitors in the output stage which dillen can also supply but are not part of his basic kit.  If the trimers look dodgy then also change these and once you have done all this then you should setup the receiver in accordance with the service manual.  You will be pleasently surprised with the final result Big Smile
    Richard
    Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
