Latest post 05-18-2007 2:55 PM by Medogsfat. 3 replies.
Page 1 of 1 (4 items)
  • 05-17-2007 10:50 AM
    Spare parts for RL60.2 speakers
    I just bought a pair of RL60.2 speakers via eBay and they are playing fine. Their finish however is "used" and this is why I´m looking for some spare parts.
    Are there replacement straps available for the RL60.2 speakers?
    Can the cloth grille be replaced?
    Hagen
  • 05-17-2007 11:51 AM In reply to
    • Beowulf
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Derbyshire
    • Posts 143
    Re: Spare parts for RL60.2 speakers
    Hi Hagen,
    They seem to come up on ebay and are a good match, however they do not have the red lettering on them.
    Might be worth trying to apply the lettering  with Letraset if you can source some in a soutable typeface from a graphic supplier.
    Good luck
    Dave
    Beowulf
  • 05-18-2007 2:19 PM In reply to
    Hi Dave,
    what do you mean with "they seem to come up on ebay"? The Speakers or the spare parts?
    What red lettering are you talking about?
    Indifferent
    Hagen
  • 05-18-2007 2:55 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    It's the straps that appear on ebay every so often. The red lettering is the speaker model which is printed on the lower of these straps.
    Reclothing is possible as I've done it myself with good results but it isn't very easy. Lots of screws to undo to sperate the cabinet and gluing the cloth back into the front to recreate the Bang & Olufsen writing which appears embossed is really quite tricky.
    Chris.
